Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Newb Setting up serial Wide band
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    Default Newb Setting up serial Wide band
    So Im totally new at this and was wondering how do i go about setting up my new serial wide band sensor for inovate to work with EFIlive
    For doing my Auto VE
    I see some information in here
    http://download.efilive.com/Tutorial...20Tutorial.pdf
    But im wondering if its different for the serial wide band?
    This is the sensor i have
    http://www.amazon.com/Innovate-Motor...=2QJYGDN3NXT1S
    Hi HKH welcome to the forum
    Which year/model/vehicle do you have...?
    Setting up V2 for serial wideband data from LC-1:
    V2 serial/digital wideband logging:
    showthread.php?t=8858
    showthread.php?t=8115
    showthread.php?t=10251 post #2
    V2 serial/digital AFR input (LC-1):
    showthread.php?t=7532
    showthread.php?t=8348
    showthread.php?t=9340 post #3
    LC-1 free air calibration from V2:
    showthread.php?p=93571#post93571
    Some tuning methods (look at how Lambda is used instead of AFR):
    A-New-Twist-on-CALC.-VE-Table..Computing-the-Entire-VE-Table.
    Calculating-MAF-Airflow-From-VE-Table..CALC-VET-In-Reverse
    If you want to do the AutoVE tutorial, use Lambda instead of AFR for the BEN (the Calc.VET tutorial has a calc_pids.txt file)...
    i.e. define the BEN to be {GM.EQIVRATIO}*{EXT.WO2LAM1}
    look at WO2BEN (CLC-00-110) in this calc_pids.txt file (from the Calc.VET tutorial): calc_pids.txt
    Also, you might want this:
    Configuring V2 for BBL/BBF :
    showthread.php?14351-BBL-PIDs-V2
    showthread.php?13841-What-is-BBL
    showthread.php?13836-New-V2-help-find-exlporer
    showthread.php?15492-V2-BBL-saving-log-data
    Mar 2011
    Thanks for the quick response ill see what i can figure out...
    I have a 1997 chevy k1500
    383
    The parts list...
    180-High Flow T-Stat
    Magna core Spark Plug wires
    BBK 82mm LS1 Throttle body
    Marine intake Extensively ported and polished gasket matched.... no barbs or rough edges here.
    45 lbs injectors.... not ordered yet
    Patriot 185cc heads 64cc combustion chamber...
    - ported
    - polished
    - gasket matched
    - Combustion chamber ported and polished
    - Stainless steel Valves 2.02 intake 1.60 exhaust
    Comp Gold Roller Rockers 1.6 ratio
    ARP thick wall push rods
    Guide plates
    Custom Comp Cam
    Intake
    224 Duration
    573 lift
    Exhaust
    230 Duration
    568 lift
    Lobe separation of
    113
    Part number
    08-000-8 Grind CS3015/3036HR113+4
    Scat rotating assembly 400 crank
    Scat Connector rods 6"
    Keith Black Pistons
    -Heat Shield Coated
    -Skirts Friction Coated
    2 bar map sensor
    Mar 2011
    So ordered that Wide band mentioned above and its no longer avaliable... discontinued....
    What is the reccomended serial wide band sensor?
    Mar 2011
    So im looking at this one
    Innovate Motorsports 3844 MTX-L Complete All-In-One Air/Fuel Ratio Gauge Kit
    But ill order what ever you see to be the best avaliable.
    The Innovate MTX works just like the LC-1/LM-1/LM-2... it uses the same serial comms protocol so FlashScan V2 can talk to it, no problems.
    Mar 2011
    So in order to get the LC-1 to hook up to the Flash and Scan V2.... for logging purposes.... What do i need to do pin out wise.... I dont want to use it as an analog..
    Do i need to get another serial cable and splice it up...? Then put some leads into the Flash and scan?
    The quickest easiest thing to do is to order an LM-2 cable from here (check with him that this is the right cable for the MTX): http://taquickness.com/taqcables.htm
  1. Wide band
    By Harrismarine in forum FlashScan V2
    Last Post: July 6th, 2008, 12:27 PM
  2. Help with wide band hookup
    By Bob's Garage in forum Gen IV V8 Specific
    Last Post: September 9th, 2007, 05:47 AM
  3. The Wide Band....how do we really know...
    By Redline Motorsports in forum General
    Last Post: January 8th, 2007, 06:51 AM
  4. wide band o2
    By woody69 in forum Custom Operating Systems
    Last Post: October 23rd, 2006, 04:19 PM
  5. lm-1 wide band
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2006, 08:39 AM
