Results 1 to 10 of 50
Thread: Update: May 20, 2013
Threaded View
    Default Update: May 20, 2013
    EFILive encourages customers to use this public update in their production environments.
    Important:
    This latest software update requires updated USB drivers (V2.08.28). You cannot use this version of the software with older versions of the USB drivers.
    If you are having difficulty connecting to FlashScan/AutoCal after installing this update, DO NOT DOWNGRADE THE USB DRIVERS.
    Download here:
    Updates:
    V7
    • LS1 controllers no longer appear locked when attempting to read/flash.
    • Enabled GM.EOPS PID for all controllers - even though on stock F-bodies that PID will not return valid data.
    • *.cax files for some older controllers (such as the LS1) can now have user calibrations defined in the operating system area. Customers who choose to modify the OS area do so at their own risk. A new Property is available: Properties->Options->"Allow *.cax files to modify OS memory for some controllers" that can be used to suppress the warning message.
    V8
    • Custom units symbol name is now saved and loaded correctly in the BBX window.
    • Custom units and alarms are preserved during PID copy/paste operations.
    • PID selection order is preserved in BBX PID selection window.
    • Fixed "Error $0101" error on splash screen test button in EFILive Explorer.
    • VIN licenses are now automatically backed up to \My Documents\EFILive\V8\Backups whenever a controller is read or flashed in pass-thru mode.
    • Allow BBX and Scan windows to be made smaller without hiding the search text box.
    • USB 3.0 ports are now supported correctly.
    • E92 read and flash options are now supported.
    • Installing old drivers via EFILive_USBManager is not supported if V8.2.2.225 or later is installed (or if V7.5.7.231 or later is installed)
    Firmware
    • Fixed "Record All Diags" option to include freeze frames.
    • Fixed System Readiness Test results to display supported/not supported as well as the usual ready/not ready status.
    Known Issues:
    Please post issues, questions, clarifications (large or small) in this thread.
    As issues are reported and confirmed they will be re-posted as "Known Issues" below.
    • When View->Small Buttons is active, the "space available" indicator at the bottom of the [F5: BBX] window is missing. Workaround: deactivate the View->Small Buttons (Fixed in the next update).
    • Custom units are lost when opening or reading the Options.txt file in the BBX window. (Fixed in the next update).
    • Access Violation error may occur when reading the Options.txt file from FLashScan/AutoCal. (Fixed in the next update).
    • Black Box Logging shows corrupted display when retrieving SRT results . (Fixed in the next update).
    • PID DTCFRZF shows as <0002> in LS1 (and some other VPW controllers') freeze frame displays . (Fixed in the next update).
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 232
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 226
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.04 (Dec 12, 2011
    To view the installed version, Select F7: Licenses (in the V8 Scan and Tune software).
    Firmware: V2.07.41 (May 20, 2013)
  1. 2013 Cadillac ATS 2.0L..
    By scdyne in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 10th, 2013, 01:50 AM
  2. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
  3. EFILive RC 2 (March 28, 2013)
    Last Post: April 9th, 2013, 12:24 AM
  4. EFILive RC 1 (March 01, 2013)
    Last Post: March 27th, 2013, 10:00 AM
  5. 2013 models supported?
    By horst in forum General (Petrol, Gas, Ethanol)
    Last Post: December 21st, 2012, 10:53 AM
