Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 67
Thread: Update: Sep 12, 2014
  1. #41
    Dec 2012
    Rather than reprogram Options.txt, Config files and then move your 5 tune files you should utilize the Quick Setup. The Quick Setup will allow you to set the remote license on all 5 tunes WITHOUT opening the tune files, and other security levels (if selected) auto-adjust, so in your case if you attempted to select FULL FLASH for an E86B, the software would automatically adjust your compatibility to CAL-ONLY.
    Cindy
    I knew about the Quick Setup. Just haven't sat down and played around with it yet. Will do that later tonight. We got the truck flashed successfully tho
    Josh
    '04 GMC LLY
  2. #42
    Is the TC1796 RSA protected also? Just outta curiosity and clarification.
    All Bosch TriCore based ECM's are, all of them and the level of protection gets worse with each new ECM
  3. #43
    Paul.. Back to the drawing board.. The new update does not fix the problem with the cax.... It's made it worse.
    sending E-mail now.....
    Kory... Please test your tunes with .cax cause I every file I open blocks my .caxs and then say the tune file is a "bad tune file format"
    What's happening on your end?
    Chuck CoW
  4. #44
    Chuck, have you sent all the files you are using to Paul to see if he can duplicate it?
  5. #45
    Dec 2012
    Quote Originally Posted by Chuck CoW View Post
    Chuck CoW
    Getting the same exact thing.... If I open a file with the CAX active i get this...
    Rename CAX to something else and file opens just fine.
    What files do you want emailed to you and where to email them?
    Josh
    '04 GMC LLY
  6. #46
    Dec 2012
    Quote Originally Posted by garrettg.bpd View Post
    It appears that only paste is not working when Internet Explore is running and minimized
    Just tried this... and copy paste is working fine for me with IE running and minimized. Im on Win7 and using a LLY Dmax File.
    Josh
    '04 GMC LLY
  7. #47
    Oct 2011
    Still having the issue with .cax file on Build 265.
    The address defined in the cax is not $FFFFFFFF
    It will not load either the cax or the calz calibrations. It shows unrecognized PCM and saves the file as BadTuneFileFormat.tun
    03 6spd
  8. #48
    Nov 2005
    I no longer have the ability to open any .bin files in v7.5 tuning tool. Can that be remedied asap please? :-(
  9. #49
    Nov 2005
    Also gives an Integer overflow error in V8 Tune tool upon loading a .bin
  10. #50
    Apr 2011
    I do like the newer version of the quick setup. Can an additional option be added to security description defaults (or somewhere similar)? I would like to see this option: Private, Full Flash, Set Device License to Flashscan Serial, and Link to Remote Autocal. This would allow all options to be set at once. I would also like to be able to lock the tunes without having to save the quick setup as a new file so that I can just program the quick setup into an autocal. I don't need the saved file. Hopefully this makes sense. Maybe I am missing a something, IDK...
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  1. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
  2. Update: Jul 04, 2014
    Last Post: July 8th, 2014, 09:56 AM
  3. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  4. Update:Sep 25, 2013
    Last Post: October 15th, 2013, 03:03 PM
