Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: March 2016: EFILive Pre-Release
    Default March 2016: EFILive Pre-Release
    Both the V7.5 and V8 software were updated in this release, you must update both software packages.
    Please use the latest Release Candidate version now available in this thread:
    https://forum.efilive.com/showthread...se-Candidate-1
    Release Notes:
    Updates
    1. Both V7.5 and V8 installation files above have been re-signed with the correct SHA256 certificates and should no longer be flagged by Windows as having corrupt or invalid signatures.
    2. The calibration definition for E78 OS 12654014 has been updated to prevent the "Invalid floating point" error. Download the attached 12654014.calz file and save it into the folder: C:\Program Files (x86)\EFILive\V7.5\Calibrations\E78, overwrite the existing file.
    Known Issues
    Please post new issues, questions or clarifications (large or small) in this thread.
    As new issues are verified they will be posted in the Known Issues thread.
    Version Numbers:
    After installing the latest release you should have the following software, boot block, firmware versions installed:
    EFILive V7 software: V7.5.7 Build 303
    To view the installed version, select Help->About (in the V7 Scan or Tune software).
    EFILive V8 software: V8.2.2 Build 294
    To view the installed version, select Help->About (in the V8 Scan and Tune software).
    Boot Block: V2.07.07 (Feb 07, 2014
    To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    Firmware: V2.07.97 (Mar 04, 2015
    To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    The EFILive Development Team
    Jan 2016
    I keep getting the error "The signature of EFILive7.5.7.303_Setup (1).exe is corrupt or invalid.
    Quote Originally Posted by Orange Stroker View Post
    The SHA1 signatures have been updated to SHA256 signatures, please re-download the files.
    Jan 2016
    Same thing for V.8
    Jan 2016
    Does anyone know what happened to the GMLAN tab under engine diagnostics for LML Duramax trucks??
    Aug 2008
    I have noticed that missing as well. I also notice that tuning the A50 in a LML truck doesn't do what you ask of it. For instance following shift points via speed or Rpm does not follow the set parameters. Tuning one in a 2010 LMM does what you ask of it.
    Lifetime Member bobo's Avatar
    Nov 2005
    Quote Originally Posted by S Phinney View Post
    Hoping we can work to solve that problem at some point.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Guys just something to be aware of. Your V2 must be plugged in to the USB port when V7.5 is first opened for these calibrations to become visible. That also means you must not have V8 running at the same time as it will not release the USB port to V7 on start up. Just something to observe when you first run V7, look for the LED's on the V2 to flash briefly as the software starts, this indicates V7 has negotiated with the V2 what level license the unit is (which is what determines if those cals show).
    Aug 2008
    Thank you for the help. Works everytime.
    Dec 2005
    I tested a 2012 and 2013 OS and had it follow my changes
    www.mscservices.net
  1. Known issues with the March 2016 Pre-Release
    Last Post: March 23rd, 2016, 05:16 PM
  2. March 2015, EFILive Release Candidate 1
    Last Post: March 20th, 2015, 07:04 PM
  3. EFILive Pre-Release 05
    Last Post: July 16th, 2013, 12:20 PM
  4. EFILive Pre-Release 06
    Last Post: March 29th, 2013, 04:15 PM
