does any one have a diagarm to make the serial cable for the v2 with the 9 pin serial port to the 6 pin phone jack looking connector. hope i am explaining correctly.thanks
You should have got one with your V2. It would be easier (and cheaper) to order one through one of our resellers, we don't try to make money on spare cables, it more to cover costs and provide a replacement service.
Cable wiring diagram (for LC-1): FlashScan-to-LC-1-Serial-Cable-Diagram
Your V2 came with a DB9 serial cable...
Your wideband came with a DB9 serial cable...
You need a null-modem adapter (orange item in pic below)... [it has to be a null-modem adapter and not just a gender bender].
To enable serial AFR in the V2, see here: Tutorial-FlashScan-V2-Serial-Wideband-Logging
You also have to remember to plug the null terminator plug (blank 2.5mm stereo plug) into the LC-1's SERIAL IN cable.
This is the null-modem adapter: http://www.sfcable.com/cable/p/30D1-C1-S.html <-- less than $5 shipped
i cannot find my db9 cable but i bought a 6 pin jack and a DB9 female to RJ11. will this work?
i found my cable. now can i connect it with a null modem adapter and cut the end off a serial cable and connect to the fjo wires?
If you can identify Tx, Rx, Gnd, then you wire them as shown in post #6 and you don't need the null-modem adapter.
If it doesn't work, swap Tx and Rx.
thx i will try tommorrow
The AFM1500 pins are as noted;
pin #1= Rx
pin #2=Tx
pin #3=Grnd
According to the AFM1500 manual;
DB9 Female (to PC)
Terminal Number
#2 (Rx) to pin #1 of module (male)
#3 (Tx) to pin #2 of module (male)
#5 (Gnd) to pin #6 of module (male)
I assume "to module" is the AFM1500 box and the "to PC" is the feed heading to the V2??
Trying to reason through the null modem conversion. Ughh!
Howard
www.redline-motorsports.net
1-954-703-5560
2006 ZO6 895/866 with APS TT
2011 HTR-850R Camaro
Are you trying to bypass a Null Modem?
RS232 serial cables pinout
LC-1 WBO2
