Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: AD filtering question?
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default AD filtering question?
    In the V2 control interface under AD filters what do the numbers 0 thru 5 represent. Sample rate? Damping? Where is the info on this in the user's manual. I couldn't find anything.
    I have been working for several days trying to get the AFR readout on the dashboard to read correct. It is always 1.1 to 1.2 AFR higher than the actual but it is steady now. I'm baseing this on 3 things while running in closed loop...(1)Afr reading from the FJO to the laptop thru serial cable...(2)the narrowband sensors controlling to 14.63 and watching the L-trims...(3)sight, sound and smell for richness or lean and how the engine idles and responds to air- rpm picks up when rich and you add air.
    I have went thru the calibration process and without the engine running everything is correct. Tried altering the expression to make it read 1 AFR lower but that didn't work either.
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    Nov 2006
    AFR will float no matter what until you go WOT
    then AFR should be at it's steadiest.
    In CL AFR will float +/-1AFR that is what the NBO2s do,
    AFR will never be solid like commanded AFR is.
    In my experience it can be difficult to distinguish rich/lean by smell.
    If adding/subtracting the offset in the sae_generic.txt or your calc_pids.txt
    does not change things then check to see if the analog ground gives 1volt.
    I don't know how the ADFILTER in the V2 works or what setting is best.
    I think the FJO can be used with serial connection, have you looked into that?
    LC-1 WBO2
    The AD filter number is the number (n) of samples used to average/smooth the AD signal...
    n = 0, 1: no averaging.
    n >= 2: averaging over n samples.
    This isn't in the user manual yet.
    Nov 2006
    A lot of things are not in the manual right not.
    What is n, can that be defined by the user?
    LC-1 WBO2
    Yes, go into V2's setup option screen.
    Dec 2005
    I have all the grounds tied together. My FJO does not have a dedicated anolog ground. You would think with my FJO setup to give 0v-5v=10AFR-20AFR then this expression would take care of my problem...
    AFR=V*2+9 instead of AFR=V*2+10
    My FJO uses a serial cable connected to my laptop and works with the FJO software installed. Reading the AFR this way seems to be very accurate but does not give the feature of using the BEN map in EFIlive. How can this be introduced into EFIlive? I don't see a serial port on the V2 interface. What am I not grasping here?
    Nov 2006
    It is the jack next to the USB 1.0 port.
    You will most likely need a null modem not a gender bender with
    the RS-232 cable that came with the V2 and you won't be able to use the FJO
    software for logging. (no big deal)
    Analog is a bit slower and not as consistent as serial with my LC-1 so don't feel bad.
    If the V2 reads a reliable voltage supply properly then the ADs don't need calibration.
    Can you change the response time of the FJO?
    LC-1 WBO2
    Quote Originally Posted by 67SS509 View Post
    See these links for male-null-modem adapter (I don't know what cable your FJO cam with):
    showthread.php?t=9340
    V2 serial/digital wideband logging:
    showthread.php?t=8858
    showthread.php?t=8115
    showthread.php?t=10251 post #2
    V2 serial/digital AFR input (LC-1):
    showthread.php?t=7532
    showthread.php?t=8348
    V2 serial/digital AFR input (PLX):
    showthread.php?t=7726
    With serial cable, you log the serial AFR pid WO2AFR1...
    the serial BEN is BEN1...
    you have to copy one of the analog BEN maps and edit it to use BEN1, and save the map with a new name... you will now have a serial BEN map.
    A null-modem adapter is different than a gender bender.
    Dec 2005
    Looks like I had my next question answered before I asked it
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 11:10 AM
  2. Filtering DFCO Cells
    By Tordne in forum General
    Last Post: June 27th, 2007, 02:18 PM
  3. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
  4. Filtering Data
    By bink in forum General
    Last Post: August 13th, 2005, 12:35 PM
