Shawn,
Not cylair or variant. just gm.dynair vs. sae/gm.maf. Those are measured in gm/sec. They are calculated from VE table and measured from MAF. I have some difference(see Post#1) btwn the two and would like to simply factor the difference into the VE in order to make both the same.
In my short sight, I trust the MAF cal. I will use it to create VE table. I will adjust IFR in an effort to set AFR with consideration to new timing map. This is a stock system. It seems to be a simple method of balancing the tune. It has already responded favorably to my harsh adjustments.
S
