Results 1 to 10 of 19
Thread: Missing while accelerating - not WOT
    Mar 2011
    Default Missing while accelerating - not WOT
    Hello guys, I have a miss while i'm accelerating....it is not one dead miss but multiple slight misses while i'm under light-medium throttle (not in boost). I have attached a log of it occuring a couple times (starting at frame 1674 and again at 3240). What do you recommend that i log to find the culprit? I also included my tune. p.s... the idle is a mess but i'm about to start on that.
    Log_0016.efi
    geoff original.tun
    Any help would be great, thanks!
    I am out of town this week so I can't view the files... when it misses what does the commanded AFR say and what do the LTFT say...?
    Mar 2011
    i tried more fuel and it didn't seem to help. I pulled timing and it seem to get worse so i added it back. I think i have a valve float issue (seperate issue) over 5000 rpm's so i will tackle that and update next week if my light acceleration miss still persists. I will log the ltft. thanks for taking the time.
    Mar 2011
    Log_0033.efi
    geoff original.tun
    Ok, i changed my valve springs so now back to the orignal problem. I logged the LTFT's today with the log included and i also included my latest tune. It missed pretty bad from around frame 4020 - 4045ish... i blipped the throttle a few frames later so i would know where to find it on the log so please ignore the spike at around 4060. I forgot to include the spark advance on this pid but it is normally in the upper 20's to lower 30's while cutting up at part throttle. Thanks joe, any info would be very helpful. Tracy
    I'm looking at your files, I don't see anything yet...
    At frame 4036 the wideband shows a lean spike... and DYNCYLAIR and DYNAIR don't look right compared to MAP, this means maybe your VE table is not right...
    your VE table has rift's in two directions right about where the frames you mentioned produce the crosshairs in the VE table:
Name:	VE table is suspect.png
    Mar 2011
    Yes, that is a big spike alright.... I'm new to tuning, you are saying that my fueling table is goofed up or my AEM wideband is not accurate? Sorry if a stupid question I forgot to mention that this is a twin turbo car if that makes a difference. Thanks so much
    You can sanity check your wideband by commanding CL or SOL and seeing if the wideband reports lambda 1 and stoich AFR.
    BTW: in B3647 any cells that are stoich will trigger SOL which uses STFT's to trim to stoich, watch out for this when correcting the VE table.
    The VE table is not right with that ridge and the hole adjacent to it.
    Mar 2011
    If i understand you correctly, you are speaking of the big changes in fueling around the "cross" on the table? I think i will just go back to my original ve fueling since i chopped this one all to hell....lol
    I check my wideband via my efilive software or my AEM gauge? Can you tell me what CL and SOL are? Sorry for all of the question but this is really a huge help!! Thanks tracy
    Mar 2011
    geoff original.tun
    Wow, the original VE fueling (boost and non-boost) look so much better.... After i make changes, i obviously need to take a look at the graph to make sure there are no rifts/holes.... lol....
  1. Throttle stops working when accelerating..
    By iViLe in forum Gen IV V8 Specific
    Last Post: May 19th, 2011, 09:48 AM
  2. Still a Bit Rich @ WOT.. What am I Missing?
    By tatasta in forum Gen III V8 Specific
    Last Post: June 20th, 2009, 12:24 AM
  3. E38 Missing tables? Or I'm missing something?
    By gmtech16450yz in forum E37, E38 & E67 PFI ECM's
    Last Post: January 7th, 2009, 03:28 PM
  4. PID's Missing or am I missing something
    By dperry in forum Duramax LLY
    Last Post: March 1st, 2007, 03:15 PM
  5. What am I missing?
    By 1morews6 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2006, 02:36 PM
