Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 98
Thread: Update: June 06, 2013
  1. #21
    Quote Originally Posted by Brads_rs View Post
    Just installed the updated version of both V7.5 and V8. V8 works fine. The tuning software however does not. Program locks up when starting up (detecting V2 flash scan). If i unplug the V2 the software starts up just fine, only freezes when i have the v2 connected. I tried reinstalling several times, with no luck. V2 has updated firmware and boot block. USB drivers are current. I have to be overlooking something. Please help
    Same thing Here
    If you're having USB issues, the best thing to do would be to explain the issues either here in this thread or directly to me at [email protected], and I'll try and figure out the problem and how to fix it.
    Having same issue as others in this post
    Which driver are you using...?
    The newest one from the update
    Quote Originally Posted by 2007 5.9 View Post
    THIS!!!!
    I cant close scantool after a run without unplugging the V2...
    Same here
  2. #22
    Dec 2010
    The auto-update feature is also now active so you can now update from recent builds as explained on the downloads web page.
    Regars
    Is there any way to assure and Auto Update does not happen to V7.5.7 build 211 ?
  3. #23
    Feb 2008
    I am using the newest driver 2.08.28. It is the only one that the software will allow me to use with the new version of V7. Has anyone figured this out yet? I have a car sitting on the dyno, that needs to get done asap.
  4. #24
    Apr 2006
    This went public?
  5. #25
    Quote Originally Posted by EagleMark View Post
    Auto-update does not mean the software will update by itself.
    It just means when you select the "Check for Updates" option the software can be updated automatically without downloading the entire installation.
    If you don't want to update, just don't select the "Check for Updates" option.
  6. #26
    For anybody experiencing USB connectivity issues, please see this thread:
    http://forum.efilive.com/showthread....066#post193066
  7. #27
    Jun 2011
    Default Re: Update: June 06, 2013
    THIS!!!!
    Same problem here but with all these issues I'm still on the previous software release. I have had this issue since day one. Also 7.5 tunetool hangs when opening up a file while v2 is pluged in.
  8. #28
    Nov 2010
    No different...still hangs with V2 plugged in.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    [email protected]
    www.youtube.com/ljszmidt
  9. #29
    Do you have access to powered USB hub? One that has a wall-plug power connection? If so can you try hooking up FlashScan via the powered USB hub?
    There are some PC's laptops that have implemented their USB interfaces with a problem that causes the USB interface to hang if/when too much electrical noise is on the USB bus. Placing a hub between FlashScan and the PC/laptop usually resolves the issue.
    If you don't have a powered USB hub, can you try FlashScan in each of the USB ports on your system? Some USB ports are physically wired to different USB hubs within the PC/laptop and some of those internal hubs behave differently.
  10. #30
    Nov 2010
    Default Update: June 06, 2013
    I've moved it between all of the 3- I have on my laptop.
    No powered hub around. I am buying a new laptop this weekend, so hopefully it'll work with that.
    All this started with the last 2-updates....
    Never an issue before, and I haven't had to do a W7 update in a while.
    Les Szmidt
    2007 5.9 Dodge Ram
    [email protected]
  1. Update: May 25, 2013
    Last Post: June 11th, 2013, 05:28 PM
  2. Update: June 05, 2013
    Last Post: June 5th, 2013, 04:26 PM
  3. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  4. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
  5. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 11:09 AM
