I'm still trying to figure out if the current firmware will still work with that version, meanwhile...
The calibration-only-flash and the full-flash options are available in version 8 of the EFILive software. I recommend using them instead of the V7 flashing options. The V8 options are more advanced and more stable.
Also from your message above, does the V7 software only hang when you load a custom OS? Or does it hang no matter what file you are loading?
Does it still hang if you remove the list of recently used files so that it doesn't try to load any file at start-up? File->Recent files->Clear file list
If it only hangs when a certain file is open, can you please send me a copy of that file? (send to [email protected])
Had to head out. Will try the version 8 recommendation tomorrow am.
It hangs on the startup even with the recent file list cleared. After you pull the cable and it completes the startup, subsequent files seem to open ok. However at no time do you ever remove the Restricted to: Personal Scan&Tune mode in the About file so no write entire are enabled.
Thanks and look forward to you answer on the V7 software/firmware answer.
Thank you,
Ed M
Also, the V8 Full Flash software for the LS1B has a disclaimer before you execute the full flash about the TPS out of range not being detected and you must re-save the file prior to flashing or you may render the LS1B PCM inoperative. Do I have to resave the Custom OS file prior to the flash?
Thanks,
Ed M
I am having the same problem I was running version 7.5 with no problems then I had to update to version 8 and update the bootblock and firmware in order to flash a tune from Rob Coddens in a kodiak now I can not do anything v7.5 freezes 1/3 of the way when stating loading calibration definitions. I use a sony with windows 7. Ive tried deleting the older version of v7.5 that I was running and downloaded the newer 7.5 with no luck.
Thanks, Stuart
Ed, can you log from V2 BBL (and transfer file to PC)...
The attached firmware has been modified to allow it to operate with older versions of the V7 software.
Specifically it will allow connections to V7 from build 230 to build 237 inclusive.
Use the V8 EFILive_Explorer program to reprogram this firmware into your FlashScan device.
Warning:
I can't be 100% certain that using the older V7 software with this latest (modified) firmware will work as expected.
Using old and out dated software will expose you to problems that have been fixed in the latest build.
Please see this page for a list of differences between V7.5.7.230 and the latest release.
https://www.efilive.com/index.php?op...tes&Itemid=134
Thanks Paul, quick question, is this FW considered an upgrade from the original build 235 FW. Would there be any reason we would have to go "back" to the original build 235 FW release? Also is there a plan to correct the issues with the 235 build to get it to operate with your latest FW above?
Ed M
