Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 60
Thread: Update: Aug 24, 2013
  1. #21
    Jul 2012
    No changes have been made to 6.7L calibration files at this point.
    Cindy
    Any expected time frame for a 6.7 release?
    2006 Ford F250 Super Duty, 2008 Cummins 6.7, Allison 1000 5spd
    2011 Ford F250 Super Duty, 6.7L Scorpion
  2. #22
    Sep 2003
    Yesterday, I tried to 'Full-Flash' an LS1-A PCM with just the V2 and got an Error message 'Script not found'. I was able to 'Full-Flash' with a laptop and V7. I can 'Cal-Flash' with just the V2. I have the latest builds, bootblock and firmware.
  3. #23
    Quote Originally Posted by Ninety8C5 View Post
    LS1A full flashing is not implemented in V8 (yet). I am trying to figure out why. I'm not sure if there is a valid reason or if it has been an oversight since day 1.
  4. #24
    Sep 2003
    I think I full flashed the LS1A with just the V2, but it was awhile ago, so I can't be certain.
  5. #25
    Aug 2011
    Hows the fix coming along to be able to switch csp5 with out going back to previus version. thanks
    Tuning by Zack StarLite diesel
  6. #26
    Nov 2005
    Default Update: Aug 24, 2013
    Quote Originally Posted by beav View Post
    I don't, but if you send me a PM with your OS # Ill see what I can do.
    Cindy
  7. #27
    Nov 2005
    Quote Originally Posted by easymon View Post
    From the CSP thread a day or so ago....
    Cindy
    The CSP updates are all done and firmware synced up with the changes, some testers will get the files this week, probably as early as next week everyone will be able to download the updated files, just hold tight if you can, you'll save yourself a lot of messing around if you do.
  8. #28
    Jul 2012
    PM sent.
  9. #29
    Sep 2013
    Does this update include EGR/DPF restrictions for US customers?
  10. #30
    Quote Originally Posted by dr_goodwrench66 View Post
    No not yet, when those options are changed/removed the fact will be identified clearly.
    They are scheduled to be removed in the first update following the public release of CSP5 switching.
  1. Update: Aug 06, 2013
    Last Post: August 29th, 2013, 12:32 PM
  2. Update: June 06, 2013
    Last Post: August 4th, 2013, 09:24 AM
  3. Update: May 25, 2013
    Last Post: June 11th, 2013, 05:28 PM
  4. Update: May 20, 2013
    Last Post: May 24th, 2013, 04:25 PM
  5. Update: May 15, 2013
    Last Post: May 22nd, 2013, 07:01 AM
