Update... it's not the .bin file itself. It is the .cax as others have noted.
I have not RE-SENT them but he already has the file I sent him when I discovered the problem in the first place.
You know me.... Updating EFI LIVE has always been a last resort for me and I always run several versions behind.
The only reason I updated is because I was on the dyno and from one minute to the next my V2 just simply stopped
communicating with the vehicle I was working on and after 2 hours of unsuccessful reboots and driver follies, I reached out
to Paul for help.
He suggested the latest software which did absolutely repair the connectivity issue (no idea what the problem actually was)
but left me unable to open or edit tune files.
I've been working (suffering) with this for 2 days now, but I know absolutely for sure that something is bobbled up in the sequence of
events just after he loads the file to memory, loads the calz, cax, and builds the navigator.
I do know for sure it has nothing to do with the file I'm using.
Chuck CoW
You don't need to save prior to programming a quick setup, however the Save process DOES update the lock icon displayed next to each tune. You 'should' create a base Quick Setup and open that as a minimum each time you use the Quick Setup to set your [F2: Scan] and [F3: Tune] controllers, otherwise they will default to the last loaded Options.text file used, each time you enter the Quick setup menu.
The security setting defaults are broken down into 'like processes', and technically the Device license and AutoCal remote license are not security settings. The remote license is an 'enabler', it does nothing more than gives permission for an AutoCal device to flash tunes from a particular FlashScan, while the device license restricts other FlashScan's from using those tunes. It doesn't need to be a 3 step process like you describe though, it can be cut to a 2 step process.
Should the tune be created with no restrictions, you can add it to the Quick Setup (you'll notice all license fields are blank and the tune icon is unlocked), then click on Link to Remote AutoCal and it will set the Device license, AutoCal and Master license in one pass. A locked tune file, or having some parameters set in the [F4;Properties] tab in the tune file will change how the security is managed.
Cindy
Josh
'04 GMC LLY - L5P, Motech, 6-Spd Conv. ML Trans.
Just to confirm there is still a problem with processing *.cax files. The problem has been identified and is being fixed. An update (V7.5.7 build 266) will be posted in the next few hours.
LOL... i always dismissed this when it happened and closed/open.......
When loading a .cax file in build 266 :
If a 3D table is defined, and the X axis is defined by another calibration but the Y axis is a fixed value, it will show an error that the address is outside the controllers boundaries.
If both the X an Y axis are defined by another calibration or are a fixed value that calibration will load fine.
Other than this, the update seems to be working OK.
03 6spd
