Page 7 of 7 FirstFirst ... 567
Results 61 to 67 of 67
Thread: Update: Sep 12, 2014
  1. #61
    Dec 2012
    Thanks for all the hard work on a Saturday Paul! Things are working good over here so far!
    Josh
    '04 GMC LLY
  2. #62
    Apr 2011
    Should the tune be created with no restrictions, you can add it to the Quick Setup (you'll notice all license fields are blank and the tune icon is unlocked), then click on Link to Remote AutoCal and it will set the Device license, AutoCal and Master license in one pass. A locked tune file, or having some parameters set in the [F4;Properties] tab in the tune file will change how the security is managed.
    Cindy
    Thank you for some calcification, Cindy. When I select "link to remote autocal" it only sets the autocal license. That selection does not also select the device and master license as described.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  3. #63
    Quote Originally Posted by ATPCummins View Post
  4. #64
    Apr 2011
    Thank you, Paul.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  5. #65
    Nov 2005
    Thank you, Paul.
    Sorry I forgot about that setting, even more embarrassing is it's caught me out too many times than I care to admit. The good news is, it's featured in the next newsletter!
    Cindy
  6. #66
    Apr 2011
    Cindy
    It happens! After using the new quick setup process for a while now I really like it.
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  7. #67
  1. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
  2. Update: Jul 04, 2014
    Last Post: July 8th, 2014, 09:56 AM
  3. Update: Jun 16, 2014
    Last Post: June 20th, 2014, 02:51 PM
  4. Update:Sep 25, 2013
    Last Post: October 15th, 2013, 03:03 PM
