Quote Originally Posted by Jimmysparkles187 View Post
Just to clarify I need to build 2 jumper wires to jump pins d and b to the auto cal odb2 connector?
Correct. Ideally you would need terminal pins that match the connector, but if you're careful, you can probably use a paper clip or similar metal object to make the connection at the splice pack. Just be sure not to spread the terminals open.
And yes, you'll connect the Autocal at the DLC as usual.
