Page 4 of 26 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 253
Thread: Flashscan data logging..
  1. #31
    This is what I meant:
  2. #32
    Default Options.ini file...
    Quote Originally Posted by waterbug1999 View Post
    where are these and how do I add them?? Im guessing I need these as I have no PIDs in the flashscan tool.
    The Options.ini file is located at C:\Program Files\EFILive\V8.1\Programs...
    Using EFILive Explorer (EE) drag that file from the upper pane (positioned on the folder C:\Program Files\EFILive\V8.1\Programs) to the lower pane (positioned on the Config Files tab).
  3. #33
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Good to go... Now what? I dont understand what it means to format anything.
  4. #34
    Goto the Scan Data tab and press Format.
    The Scan space is disctinct from the Config space.
    On the V2 setup options (navigate to there using the V2 keypad/LCD), you can set the Scan space to be either the external SD memory card or internal flash.
    Do you have an SD card...?
  5. #35
    Mar 2008
    In the EE / config files left corner "format" button?
  6. #36
    No... oops... I meant on the V2...
    1. On the V2 navigate to here: Options->Setup->Edit Settings->File Sys and select internal or SD card;
    2. On the V2 navigate to here: File System->Format File Sys and do the format.
    This formats the file system you selected in step 1.
  7. #37
    Mar 2008
    ok.. its formatting now. :-)
  8. #38
    Mar 2008
    So, its done with the formatting. So, is this as far as I can go until I get it in the car?
  9. #39
    Mar 2008
    I go into V2 to select PIDs and nothing. Am I suppose to set something up in the EE for it?
  10. #40
    Did you get it going...?
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
