Page 5 of 26 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 253
Thread: Flashscan data logging..
  1. #41
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Did you get it going...?
    I have to assign the PIDs while its plugged into the car right?
  2. #42
    Mar 2008
    Another question, I have an LC1 hard wired in with a AF gauge, I see there is the plug in for the phone looking cord in the V2, does the other end plug into the LC1 somewhere?
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  3. #43
    Quote Originally Posted by waterbug1999 View Post
    Yes, connect to car, then select the pid list, and then start logging.
  4. #44
    You need the LC-1 serial cable and the FlashScan serial cable, with a null-moden adapter between them.
    The LC-1 has a SERIAL OUT cable which takes the stereo jack;
    The LC-1 also has a SERIAL IN which takes the terminator plug.
  5. #45
    Join the LC-1 serial cable to the FlashScan serial cable using this: http://www.sfcable.com/cable/p/30D1-C1-S.html
    or buy a ready made cable from TAQuickness.
  6. #46
    Mar 2008
    Well, a buddy came over last weekend with his hptuners (still learning how to tune with my EFIlive). We hooked up the LC-1 to his HPTuners using the brown wire off the LC-1 and a ground I tagged into the floorboard, both those wires screwed into a 6 or 8 prong connection that he plugged into his hptuners so we can get AF ratios... So, it looks like it will fit into the bottom of the V2.. Do you know what I am reffering too?
  7. #47
    You mean these two pins (see attached)...
    to see the analog inputs, you have to enable the external analog inputs in the V2 options (from the V2 keypad/LCD).
Name:	V2 Analog Inputs.jpg
  8. #48
    This uses the wideband's serial output... this is different than using the V2's analog inputs shown in the previous post.
    Your LC-1 came with cable that has a DB-9 on one end... you can see it in the pic: "LC-1 Serial Cable"...
    the stereo jack plugs into the SERIAL OUT cable on the LC-1.
    TAQuickness sells a cable that is already made up (no need for null-modem adapter).
    Using the null-modem adapter I showed earlier makes connecting LC-1 -> V2 a snap, much easier than analog.
  9. #49
    Mar 2008
    will this work as good as any other?
    Also, I took the 1meg memory out of my camera and put that in the V2.. Do I need more memory or should I just buy a bigger one and put it in the V2?
  10. #50
    Aug 2007
    Lightbulb
    1 Meg or 1 Gig, if 1 Gig it will be plenty, 1 Meg not so much.
    2001 GMC Sierra 4WD ECSB SLT, 5.3 LM7, stock 4L60E, 3.73, G80, @ 165,xxx miles
    *Installed Mods - Outlaw Intake, Magnaflow #15838 Exh., #59956 Cats, AEM Bruteforce LT's, EFI Live V2
    *Garage Floor Mods - Radix MP112 Supercharger Kit, Innovative LC-1 WB O2, FLT 4L65E LVL 7, (All gathering dust in the garage! )
    *On Order Mods/ To be ordered - T/A diff. carrier stud kit, T/A diff. cover, Circle D TB modded TC, SFI Flexplate
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
