Results 11 to 20 of 32
Thread: LC1 AFR output numbers
    Dec 2005
    I opened the tuning tool>properties>data tab and I chose the AFR but the Stoich number is still grayed out.
    Could this be the issue?
    Post some screenshots... showthread.php?t=3064
    Nov 2006
    Quote Originally Posted by 1bar View Post
    It's the default setting that EFILive employs
    page 64 of the tune tool manual:
    EFILive uses the PCM’s calibrated value for stoichiometry {B3601}, which may be set slightly lower (richer) than 14.7 (i.e. 14.63). If the calibration does not contain {B3601}, then EFILive substitutes the value 14.63 for stoichiometry.
    APPENDIX-B STOICHIOMETRY page 100 of the tune tool manual:
    The stoichiometric value used by the PCM is defined in one of two ways:
    1. As calibration {B3601} Or if that calibration is not configured in the PCM (most late models do not have that calibration) then
    2. As the constant 14.63
    Your problem seems to be with the configuration of the maps you are using,
    zip those maps and post the zip.
    LC-1 WBO2
    Dec 2005
    Thanks for all the help Gentleman,
    I have never posted files like this, so I will work on it shorlty.
    Would you guys be opposed if I emailed you the files?
    Thanks,
    Glenn
    Nov 2006
    Right click> send to> Compressed (zip) file.
    Go Advanced> Manage Attachments> select zipped folder
    or like Joecar said post a screen shot.
    How to post a hosted image
    LC-1 WBO2
    Dec 2005
    Okay let see if the zip folder attaches?
    Glenn
    Dec 2005
    Dude I think it worked, you learn something new everyday
    Dec 2005
    And here is the tune I was using in the log above.
    Thanks,
    glenn
  9. #19
    Nov 2006
    Other than you running lean, I saw nothing wrong with the data in the log.
    Kudos to hitting 105kPa
    LC-1 WBO2
  10. #20
    Dec 2005
    Yeah, I knew it was lean and I added fuel. It is fatter now.
    The problem is, why can't I read AFR on my AFR LC1 map?
    Thanks,
    Glenn
  1. Massive log numbers???
    Last Post: May 8th, 2008, 10:35 AM
  2. FTC Numbers
    By white2000ta in forum General
    Last Post: January 8th, 2008, 05:19 AM
  3. Tried to AutoVE and only got 50,55, 60 MAP numbers
    By 99ss in forum Gen III V8 Specific
    Last Post: September 13th, 2007, 03:06 AM
  4. base numbers
    By BACKinBLACK in forum General (Petrol, Gas, Ethanol)
    Last Post: April 6th, 2006, 03:10 PM
  5. Table Numbers
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: March 3rd, 2006, 08:21 AM
