Page 15 of 26 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 253
Thread: Flashscan data logging..
  1. #141
    Hey Jody,
    How's it going...?
    Your LC-1 has power when the motor is running, right...?
    Do a heater calibration and a free air calibration.
    First do this:
    - connect V2 to your PC and start EFILive Explorer (EE);
    - on the bottom pane of EE, click on the FIrmware tab;
    - it should show the versions of firmware and bootblock, tell me what they say.
    Connect your wideband serial AFR cable from the LC-1 SERIAL OUT port to the RJ12 port on the top edge of V2 next to the USB port.
    Plug the stereo terminator plug into the LC-1 SERIAL IN port.
    Then you have to enable serial afr pids in the V2 setup options (navigate down into there from the V2 LCD/keypad).
    You will then be able to talk to your LC-1 from V2 (to do a free air calibration, and to read the AFR and LC-1 status).
    Send me your Options.ini file, it has now changed to Options.txt, I can transcibe the pids over.
    Joe
  2. #142
    Lifetime Member waterbug1999's Avatar
    Mar 2008
    Hey Jody,
    How's it going...?
    First do this:
    Joe
    Going good... SSDD = Same Shit Different Day.. LOL
    Im at work and wont have time to get to the car till this weekend....
    Yea, it turns on when I turn the key... I have never done another calibration on the O2 since I put it in 3 years ago. You guys have a link some where on here I can look at to refresh my failing memory?
    1999 Trans Am. 10.71 @ 126 - stock bottom end-
  3. #143
    Default LC-1 user manual summary...
    Heater Calibration:
    - power off and disconnect the sensor from the module,
    - power it on and wait a few moments,
    - then power off and reconnect the sensor to the module,
    - then power it on, wait a few moments.
    Free Air Calibration:
    - after leaving motor off overnight, use FlashScan V2 to initiate the free air calibration.
  4. #144
    Mar 2008
    Im sure its pretty black from the rich starts I had before.. Would it hurt anything to clean it up?
    Also, I can do all the above with the O2 hanging down along the pipe right, its easy to get to.
  5. #145
    Hmmm... maybe spray it with MAF cleaner when cold and let it air dry.
  6. #146
    Mar 2008
    How about electic parts/circuit cleaner?
  7. #147
    Quote Originally Posted by waterbug1999 View Post
    Yes, should be ok.
  8. #148
    Mar 2008
    Thanks... Ill let you know what happends sometime over the weekend. I will be getting the car out of storage.
  9. #149
    Mar 2008
    Hey Jody,
    How's it going...?
    First do this:
    Joe
    says version is 2.5.20
    and bootblock is 2.5.08
  10. #150
    Mar 2008
    Hey Jody,
    How's it going...?
    First do this:
    Joe
    I cant even remember how to get in to do that.
  1. BB Logging - Missing Data ?
    Last Post: July 24th, 2009, 01:01 PM
  2. Flashscan not responding when trying to data log
    By 99TransAmls16spd in forum General (Petrol, Gas, Ethanol)
    Last Post: March 11th, 2008, 07:25 PM
  3. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
  4. Data logging a 98
    By minytrker in forum General
    Last Post: February 25th, 2006, 02:10 PM
  5. Data logging
    By never satisfied in forum Duramax LB7
    Last Post: February 20th, 2006, 02:53 AM
