Originally Posted by
joecar
Hey Jody,
How's it going...?
Your LC-1 has power when the motor is running, right...?
Do a heater calibration and a free air calibration.
First do this:
- connect V2 to your PC and start EFILive Explorer (EE);
- on the bottom pane of EE, click on the FIrmware tab;
- it should show the versions of firmware and bootblock, tell me what they say.
Connect your wideband serial AFR cable from the LC-1 SERIAL OUT port to the RJ12 port on the top edge of V2 next to the USB port.
Plug the stereo terminator plug into the LC-1 SERIAL IN port.
Then you have to enable serial afr pids in the V2 setup options (navigate down into there from the V2 LCD/keypad).
You will then be able to talk to your LC-1 from V2 (to do a free air calibration, and to read the AFR and LC-1 status).
Send me your Options.ini file, it has now changed to Options.txt, I can transcibe the pids over.
Joe
