Anyone using serial output from FJO WB?
Been trying to get my EFIlive to work with the serial output from the FJO (GEN2). Can't get past "Controller Not Found" when programming the V2.
Talked with a FJO tech person today. He said it will not work with EFIlive. Now I don't know who to believe. If anyone has FJO-serial working please let me know.
EFIlive-FJO serial wideband up & running!
Thanks Paul for a job well done! Got the revised firmware from you this evening and installed it. Took a few minutes to realize I had to go back thru the V2 settings after the new firmware was installed. Now it displays the 02 reading on the LCD screen and logs correctly on the dashboard and BEN map. I am one happy camper for this accomplishment. I've got a day scheduled on the dyno tomorrow and this makes it perfect timing.:cheers:
