Results 1 to 10 of 13
Thread: LS7 (441 CID) with Light Boost in 1998 Trans Am (Need MAF advice)
    Oct 2003
    Default LS7 (441 CID) with Light Boost in 1998 Trans Am (Need MAF advice)
    OK ... I've taken the 422 Iron block out, moved the the 4.125 crank over to the LS7, purchased Diamond Pistions, three-angle valve job LS7 Heads with stainless steel valves, etc, etc ... and just got an LS7 intake. Upgrading the injectors to 80# (from the Siemens 55#'ers) and now I'm at the decision-making time on throttle body and MAF.
    For centrifugal FI, does it matter a lot beteen the 90mm and 100mm MAF? Particularly since the stock intake and throttlebody are 90mm?
    Also, since my tune is for the 75 mm MAF that came with my Trans Am (actually, an 80mm MAF on it right now), are there any tunes I can start from or import MAF for if I cnage from my stock MAF? Are there still huge hurdles to jump for a 1998 computer when changing to a larger MAF?
    I've been out of the loop for quite a while and would appreciate any help, including .tun's to look at.
    Thanks!
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Id just go speed density. Your maf table will max at 512 g/sec. If you are dead set on going with a maf setup, order a maf sensor boss from gmpp and run the new style car maf. The maf tablel will have to be setup for it, but it is a much better setup. But my vote is for sd.
    Head Calibrator
    Gwatney Performance Innovation
    Jacksonville, AR 501-982-2102
    Oct 2003
    Thanks for the advice; I will consider that. Can you possibly post a link to a good thread about the basics and setting up for SD?
    And what about turbulence of the intake from the Supercharger? How is that generally handled? Is the MAF still physically in place, just not connected? I feel like such a newbie at the moment.
    Jul 2006
    Leave the maf out, leave your iat sensor in and tune only with the ve tables. I would upgrade to an efilve custom operating system that will allow you to tune beyond the 1 bar limits of the stock ve table (if available for the 98 pcm). There is a nice writeup in the tutorial section in the help tab of the tune tool. Basically speed density is only using the map sensor, iat, and tps for fueling calculations (well and all the obvious injector tables normally used). It takes the maf out of the loop and you set your tune up based of manifold pressure.
    Head Calibrator
    No cos for 98. If it were my car I would re-pin harness and swap to 411 PCM then run cos 3.
    +1 run a 0411 PCM (repin the harness), then you can run COS3 (boost, nitrous) or COS5 (boost, nitrous, throttle VE)...
    you won't regret it
    SD is easy:
    - disable/remove the MAF;
    - disable COTS, DFCO;
    - make sure OLFA and PE are sufficiently rich;
    - correct the VE table in OL using a wideband;
    - decide if you're going to run COTS, DFCO;
    - decide if you're going to run OL or CL.
    Oct 2003
    Ok ... cool. Thanks for the simplified run-down, joecar.
    I can't find any thread about how to do the re-pin. from joecar post over on LS1Tech:
    1998: require 411 PCM
    swap, PCM connector re-pin, fuel segment swap
    I'm having trouble finding a clear, concise description on the re-pin and PCM swap
    I did find this:
    1998 PCM Pin Assignments
    http://www.ls2.com/boggs/torques/98pinpcm.htm
    Am I understanding correctly that 411 PC is simply 2001/2002 Camaro/Trans Am PCM?
    I'm sorry I'm so ignorant of all this at the moment. I got very adept at tuning my own car, but have no experience with the PCM swap and re-pin, modification to SD or tuning SD.
    Thanks!
    Oct 2003
    Is this a good route to go for a PCM?
    Flash Masters: 2001-2002 Camaro, Z/28 Engine computer 12200411 Programmed to your VIN. PCM ECM
    http://www.ebay.com/itm/2001-2002-Ca...955078&vxp=mtr
  1. Advice:427 supercharged LS9 injector/LS7 MAF
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: May 2nd, 2010, 03:25 PM
  2. ls1 with ls7 maf, sanity check, input appreciated
    By rosey in forum Gen III V8 Specific
    Last Post: November 1st, 2009, 02:51 PM
  3. New LS3 in C5 Z06 with LS7 MAF/TB + FAST 92 IM
    By -X- in forum Gen III V8 Specific
    Last Post: December 8th, 2008, 05:59 PM
  4. Use MAF for off boost/2 Bar SD when in boost
    By Earl H in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 24th, 2007, 12:58 PM
  5. LS7 MAF related question....mind as well start!
    Last Post: June 7th, 2006, 09:34 AM
