EDIT: No, that would not work with
"iff({CALC.CL}, {CALC.LTFTBEN}, {CALC.WO2BEN})"
But since the thread started as STFT I can see why you ask. LTFT is only turned off for
"({SAE.SHRTFT1}+{SAE.SHRTFT2})/200+1"
Which is not implemented in what I am doing now. That works well for Non PE and a vehicle without a wide band. I started there because it was the only idea I got from reading the RoadRunner forum.
Correct, but since all truck cals are set {B4206} to Enable you get STFT with PE. If not you spend hours over days wondering why CL LTFT is working well and OL PE sucks...
Since there are way more trucks and conversions from trucks with 0411 PCM then there are Camaro or Corvette (which don't have this issue, it's disabled)? This should really be in summary/logging notes with turn off EGR, Lean Cruise and DFCO etc...for tuning only. {B4206} Disable during tuning and left off permanatly.
