this link seems a good link for the down and dirty to go from the 98 f body to 01 and up ecu
http://forum.efilive.com/showthread....ll=1#post95418
Injector Specs
http://users.erols.com/srweiss/tableifc.htm
showthread.php?t=7790
showthread.php?p=67871
showthread.php?t=7457
showthread.php?t=7246
showthread.php?t=6947
showthread.php?12195-BOSCH-Fuel-Injectors-0280155868
An-interesting-read-on-redrilled-injectors
Injector-Config-guidance-I-think-im-getting-there
Correct-IFR-tables-for-LS3-LS7-injectors-in-Gen-III
LSx-to-LS1.zip
Idle Tuning
showthread.php?4661-Idle-Tuning-Helpful-Info-Inside
showthread.php?14439-Idle-Tips-amp-Tricks
showthread.php?5866-Auto-VE-questions
showthread.php?14153-scan-tool-wont-log-rafig-or-rafpn
showthread.php?14435-Need-help-Can-Start-Car-but-dies-when-I-give-it-any-throttle-before-going-to-CL
showthread.php?7011-ETC-cars-and-IAC-parameters
showthread.php?14544-Working-on-my-idle-tune
showthread.php?14794-Help-with-open-loop-%28cold-start%29-tuning
showthread.php?149-Idle-%28Transition%29-Tuning
Stumble-3-seconds-after-cold-start&p=178921#post178921
Idle-Tips-amp-Tricks:post#46
More Idle Tuning
showthread.php?t=149
showthread.php?t=5866
showthread.php?p=86553 post #17
showthread.php?t=2630
showthread.php?t=473
Throttle Cracker/Follower
showthread.php?t=3568
showthread.php?t=4081
showthread.php?t=5406
showthread.php?t=5940
showthread.php?14163-V2-with-LC-1-wiring
showthread.php?14243-Need-help-with-LTFT
Getting-some-odd-s-from-my-LC-1-wideband-please-take-a-look-at-my-log post #13
Yet-another-LC-1-question <-- narrowband signals from LC-1
LC-1-widband-hook-up posts #50 and #66
If you are having problems with your FlashScan
(e.g. problems with registration, installation, licenses, hardware)
showthread.php?14547-EFILive-Support
http://support.efilive.com/kb.php
Sensor part number:
showthread.php?1581-Map-Sensor-Part-s
showthread.php?14429-3-bar-Map-Sensor
showthread.php?14090-2.5-bar-map-offset-specs
showthread.php?4351-2-bar-map-sensor
showthread.php?14748-Delphi-2Bar-map-sensor-settings-Part-Number-16235939
Also note:
showthread.php?17061-Tryiing-to-log-boost-on-2009-cts-v
V2 serial/digital wideband logging:
showthread.php?t=8858
showthread.php?t=8115
showthread.php?t=10251 post #2
V2 serial/digital input (LC-1):
showthread.php?t=9340 post #3
showthread.php?t=7532
showthread.php?t=8348
V2 serial/digital input (LC-2):
LC-2-Digital-Wideband-anyone-try-it-out
V2 serial/digitial input (LM-2):
Flashscan-to-LM-2-Serial-Cable
V2 serial/digital input (PLX):
showthread.php?t=7726
V2 serial/digital input (AEM):
showthread.php?15748-AEM-compatibility
showthread.php?16636-Installing-an-AEM-Wide-Band-02-and-logging-afr
showthread.php?16904-AEM-EUGO-Lambda-W-B-how-to-connect-to-Flashscan-V2
V2 serial/digital input (Zeitronix):
showthread.php?14743-Strange-AFR-from-Serial-ZT-2-OFF-by-Factor-of-10
LC-1 free air calibration from V2:
showthread.php?p=93571#post93571
